Woodonglass
- Joined
- Dec 29, 2009
- 25,932
Re: 1970's 16 ft Aluminum Mackenzie Runabout Rebuild
When using the Homebuilt flaring tool, a couple of things are important to understand. 1.) the Tube should be cut so it sticks out approx. 1/4" to 5/16" from the surface of the transom. 2.) The nylock nut is only used to start the flaring process. Once it starts to curl, you remove the nut, turn it around to the flat side, place a washer on the bolt then tighten the nut down to finish the flaring. Note: Remove the Nylon busing from the nut to make it screw on easier. Hope this helps.
