1970s Evinrude 7.5 hp
mgsolakis
I have an Evinrude 7.5 hp and the recoil spring is shot. I have a parts motor that has a good recoil but when I went to remove the damaged spring it seems to be attached to the base. How does one remove that spring?
Daviet
Re: 1970s Evinrude 7.5 hp
If I remember correctly, there is a slot in the base that the spring goes into.
Can you post a model number?
BigB9000
did they make a 7.5 HP in the 70's?
kbait
Post a model number or pic. If it's got a metal cover, it's a late 50's model, if it's a fiberglass/plastic cover, it's an '80's. Totally different recoil setups.
Daviet
I don't think they did, I assumed it was a newer model 7.5 hp.
But we all know what happens when we assume something.
mgsolakis
Sorry guys, your right it is the 80s model 7.5 with the fiberglass cowl. I actually figured it out, it was 2 bolts at the bottom of the re-coil. I now have the challenge of getting the new spring to sit in the slot. I think it is just going to be a matter of a lot of trial and error.
