Lrdrlker
Thread starter- Joined
- Jul 28, 2016
- 31
I pulled the lower end off and changed the impeller and I don't know if I bumped the powerless shifter or what happened but when I tried to reinstall the lower end I noticed the shift lever in forward. I tried to shift it into neutral so I could SLOWLY turn the flywheel to reinstall the shifter shaft and drive shaft but NO WAY! I pulled the lower end back out so I could have both hands free to adjust the top end. Obviously it won't turn over in drive but if I press the linkage under the flywheel it bypasses the shifter and will free up the flywheel. The shifter is jammed in forward. HOW DO I FREE UP THE SHIFTER KNOB? Any advice would be greatly appreciated! Cheers
