1971 18' Starcraft Holiday Weight
DekeBlue
Anyone know what the towing weight of a 1971 Holiday might be. I'm looking for the official listed weight.
Thanks
CheapboatKev
Re: 1971 18' Starcraft Holiday Weight
From iboats themselves..bear in mind this is with an I/O...
1971 Holiday
This inboard/outboard runabout has a aluminum hull, is 18.17 feet long and 84 inches wide at the widest point. The boat weighs approximately 865 pounds with an empty fuel tank and without any gear or passengers.
ezmobee
With an I/O? No friggin' way. You miss a digit there Kev?
barato
i agree...that weight has to be for the OB version. i'm pretty sure weight for I/O would be more like 1400+. the Holiday has exact same hull dimensions as my Starchief, weights for the 2 are within 150# of each other....and mine weighs 1600 with I/O and 900ish with OB.
Pugetsound
My 22 Holiday with a 200 hp O/B - 4stroke Merc el start 9.9 , 2 downriggers rigger weights and 2 batt and fuel will be around 2200 lb.
