Buck Horn Deer Farm
Thread starter- Joined
- Jul 18, 2011
- 70
This 20R71S motor has no spark at either plug. Before I pull the flywheel, What could cause this problem on both cylinders? There are 2 wires out of the magneto that are not connected to any thing. There is a switch that the shift linkage pushes on when shifting into gear that has an empty male connector on one side and on the other side a wire to the solenoid I think. Where should these 2 wires go? And do they need to be connected to anythig for the motor to run?
