Skippy the skipper
Thread starter- Joined
- Oct 29, 2007
- 20
I've got an old head question for anyone on a 71 225 OMC electric shift stern drive I have been working on forever. It gets hot is the basics of it. Runs 3/4 on guage at idle. Will slowly climb on a load and drop back to 3/4 when you reduce rpms. I have quite a list of what I have done to it so here it goes....
ck oil, has no water in it
Changed the impeller
set timing
replaced thermostat and housing
replaced temp sensor
Replaced water pump on engine
swapped temp indicating system from other engine (still runs hot on other indicating system)
put radiator cleaner in block on warm engine to flush
removed/reinstalled intake and heads....had heads magnafluxed and valves ck by machine shop
performed flow tests on each portion of cooling system. (found values in old omc book, so much per 20 sec ect...) Passed....small bubbles at first then clear flow on clear tubing
replaced 1 exhaust manifold that was cracked, inspected other and found nothing but cleaned it out anyway.
I'm at a loss and fairly frustrated any help would be greatly appreciated. I did ck engine with dig temp gun and it is running hotter than the other side but other is a newer engine
Thanks in advance...Skippy!!!
set timing
