1971 40hp Evinrude Common Problems?
thull
i'm going to look at a '71 40hp Evinrude a guy is selling for $100. It's a model 40153g. It has a starter so obviously electric start, also has manual start. Do these motors have a "black box" ignition system? I've been told to stay away from those due to the expense of replacing them, as compared to coils, points, & condensers. Maybe since it has manual start that means it doesn't have a black box, but I'm a novice at motors & am not sure. The seller also says it needs carb work & a fuel pump, but that it was running about 2 years ago. If that's really all it needs I'm fine with cleaning the carb & the pump seems to just bolt on. They are about $50. Can anyone tell me if this sounds like a good deal or a nightmare? Thanks.
TN-25
Re: 1971 40hp Evinrude Common Problems?
As far as outboards go, the 1971 Evinrude 40 is a model of simplicity. There are no black boxes at all, just simple user-serviceable breaker points. Although the spark is not as hot as CDI and being mechanical, they are always gradually going out of tune, albeit at a slow rate, they definitely do not suffer from the expensive black box syndrome. 1971 was the year that Johnson & Evinrude decided to stop pedaling the 40 as an upscale motor since the new looper 50 appeared. The 40 was repositioned as the simple economy motor, taking over from the 33. Really the 1971 ? 1976 40 (and later commercial 40s) were about simplicity, low cost and effectiveness. 1971 was a curious year in which the 40s adopted the new parsimonious tack but still carried the 1961 cowl & base. No more ?Super Quiet? double walled lower units, thermostats (!) or pushbutton Electric shifts. Really they were considered an archaic motor when new, but that is the appeal of them today. Only 1 carburetor, so no need for carb sync tools. They are brute force motors that are solid & reliable, you generally can't go too far wrong with them. Slow revving, high torque motors that are the model of simplicity and need no special parts. I would say that you have stumbled upon a great motor (assuming it hasn?t been overheated, neglected or used for millions of hours). As far as project motors, these are relatively simple and good, complicated by the electric start & electric choke. Good motor generally. Don?t become a stranger to this forum, as these are the sort of motors that laymen thrive on.
kfa4303
Banned
Oh yeah. Good 'ol "Big Twin". They're a little thirsty when it comes to gas, but are otherwise nearly bulletproof and you can 't go wrong for $100. You can buy A LOT of gas for the cost of a modern motor of equal power. Assuming the compression is good (+/- 100psi with both cylinders being within 10% of eachother) you can fix everything else with ease. You can most routine parts right here at iboats too. Here's a handy link to do some reading on the motor before you decide.
http://www.duckworksmagazine.com/04/s/columns/max/24/index.cfm
thull
I've been offered this motor for $50. What is the part labeled "carburetor???" in the edited photo. I realize now that the carb is next to the starter (I think). Also, where is the fuel pump?5E65H45M13E63K63H1c6k74549b48970a1396.jpg5I75J25M53Ge3l93H9c6kc52e0f2061d51a07.jpg5O25M15J83I93N43l9c6ke9e35eabd4551a1d.jpgPicture1.jpg
thull
Sorry I didn't make it clear in the last post. This is the same 1971 40hp evinrude i started this thread about.
Daviet
You have the items labeled backwards in the fourth photo. The carb is in the front of the engine and the fuel pump is on the starboard side towards the rear.
jimmbo
lindy46
. . . .And that fuel pump is also early 60's
jimmbo
The fuel pumps changed in about 66 - 67
F_R
The thing you circled as a "fuel pump" is the water heated automatic choke (they rarely work right). As everybody has already pointed out, that is no 1971. Not that there is anything wrong with that, but it doesn't enjoy the high praise for simplicity that was previously given.
Expect to lay out some more money before you get it operatonal. But at $50 purchase price you can afford it---assuming is isn't misused, abused, and neglected.
