1971 50 hp evinrude drive shaft seals
grandpalong1961
still workin on my 1971 50 hp evinrude. I have another problem. I am trying to replace the seals on the drive shaft in the lower unit but the plate under the water pump wont come off. It will come up about a half inch but stops. Looking at a diagram it looks like it should slide right off but it won't. Any ideas why it's not sliding off the drive shaft?
Daviet
Re: 1971 50 hp evinrude drive shaft seals
Are you talking about the bearing housing with the 4 bolts?
Use a couple of flat bladed screwdrivers, one on each side and gently pry it out and out of the gearcase.
grandpalong1961
yes the bearing housing. I have tried that and won't move. No matter how much I pry on it it seems to be stuck. But it is supposed to slide up and off the drive shaft? I'll keep trying.
Daviet
If it comes up 1/2", it should come up all the way.
