1971 50 hp. key
manveru
I recently moved and can't find the key for my boat its a 1971 johnson 50 hp model 50ESL71S i was wondering if someone knew what key it would take, or where i could get a new ignition switch. thanks
F_R
Re: 1971 50 hp. key
No need to replace the whole switch. You need to look at the switch and get the number that you will see beside the keyhole. Any Evinrude dealer can get you a new key from that number. OR a real locksmith can make you a key from the number. Hard part is finding a real locksmith these days.
manveru
Re: 1971 50 hp. key
I've looked and there is no number, unless you have to open the controls to see it. Its just black plastic where the key goes.
boobie
Re: 1971 50 hp. key
Look real hard at the black plastic where the key goes in. Sometimes hard to read.
F_R
Re: 1971 50 hp. key
Granted, there is the possibility the switch has previously been replaced with an aftermarket one. If push comes to shove, part number is 384238, replaced by 386947, from an Evinrude dealer. List price is $63. iboats probably has an aftermarket one. I haven't attempted to figure out which one it takes.
bret632
Re: 1971 50 hp. key
Went through this myself...sort of. i didnt have a key switch or key. so i got a push to choke switch that cost me about 30.00 but you should look online for cheaper ones if time isnt a factor... im very impatient :facepalm:
manveru
Re: 1971 50 hp. key
alright i'm reviving this thread because i wired in an aftermarket ignition switch, but now i have no spark. i'm guessing i have it wired wrong and was wondering if anyone had a wiring diagram or knows which wire does what. Thanks
bret632
Re: 1971 50 hp. key
i have two diagrams that helped me. hope they do for you 22nf9l.jpg2012-02-02_151947_keyswitch.jpg
bret632
Re: 1971 50 hp. key
i had a similar issue, mine kept blowing fuses after a few sec of key being on. the warning buzzer was grounding against the case causing a short, but a delayed short
