Wilburthegreat
Thread starter- Joined
- Apr 5, 2012
- 12
Greetings all!
I purchased this little honey (we'll see!) last fall, for $300 hull/motor/trailer. 1971/72 55HP. I have been trying to do all of my due diligence work before I drop her in the water and see what she's like, and I have a few questions. First, it wouldn't spit water from the TellTale initially, so I have rebuilt the L/U (several times), and replaced the gear case seal, drive shaft seal (under the impeller housing) and impeller housing seal. There is some wearing on the shaft, around the impeller, but I have no idea how much is too much. It will start and run like a champ, with fairly warm water exiting the TellTale (not sure if it's supposed to be cold or not), while running in a bucket with the thermostat removed (it's borked).
My question, I guess, is this: I have water looks like gear oil floating on top of the water in the bucket. I have read that sometimes it's normal after having had all the components off (several times), and that it's just 'flushing' itself. Is this accurate? I like this little rig, but as parts in Ontario are getting harder to come by for this little beasty, I don't want to turn this into a saga.
I can provide pics and videos if it helps.
Cheers
WilburTheGreat
Cheers
WilburTheGreat
