etracer68
Ensign
Thread starter- Joined
- Oct 11, 2009
- 906
I went through the CDI procedure, and found that I need to check the points, and or wire too. I grounded the coils and did get spark. I need to remove the flywheel to get at the points. First I have to remove the recoil, and then the flywheel? Is there anything that may unwind when removing the recoil? And what should the points gap be set at? Thanks, any tricks, or advice is wellcome.
