1971-72? 65 mercury
googen1161
Motor is overheating, no water being expelled out of pee hole. Motor sat for 11 years but started right up. I put pentetrating oil down the cylinders and let it sit for a week, then started it. Runs fine just overheating. I'm new to boating and was wondering whats my next move to fix the problem. I have the orignial manual but Icant find overheating troubleshooting. Thanks to anyone who can help me. Glenn
Laddies
Banned
Re: 1971-72? 65 mercury
You have a bad w/pump impeller, probably just got a set in it sitting around
googen1161
Thanks Laddies, the guy at the marine shop thought the same. Now if I can just find the serial number I will be fine, lol. Thanks again for your help. Glenn
Laddies
Banned
All those 4 cyl 650s used impeller Mercury number 47-89984 or Sierra number 18-3017
papasage
blow the pee hole out it will git stopped up sitting . a good plac for buggs to hide . would replace the water pump impellor anyway . thatb old it could be rotten and break up then you will have to disasemble it to git the pices out
papasage
papasage
googen1161
WOW! What a great website!!!. Thanks for the help guys really appreciate it. I'm a fairly good mechanic but never replaced an impeller before, is this a fairly easy project or should I take it in? I got this boat free so I donmt mind spending a few bucks to repair but if I can do it myself I dont mind the work. I do have the repair manual here. Thankls again! Glenn
joblo33
It's one of the easiest things to fix on these things as long as nothing's stuck. Take the leg off, remove 3 nuts from the pump housing, replace the impellor then follow those steps in reverse. The manual should show you how to do it. Make sure you get the driveshaft key back in right (plate with a groove sticking out to line up in the impellor)<br />Eric
googen1161
Thanks Eric, I'm going for it! If anything I'll get to know my way around this motor better. I'll let you guys know how it all worked out. Thanks again, Glenn
