Re: 1971 evinrude 125hp
Sounds like you have a pretty good handle on what you're doing. I am guessing your driveshaft splines may be sticking in the powerhead. There is a two lead wire bundle leading to the lower unit that I assume you disconnected. While they're off, you might check the heads to see if the heat warped them (according to OMC manual, sheet of glass is flat enough to check them against). <br /><br />The electrical part of the lower unit contains two solenoids. When there is no current to them, the LU is in forward. Current to one moves the unit to neutral, current to both moves it to reverse. To eliminate everything but the solenoids as sources of the problem, try activating them directly, using the connectors in the powerhead which lead to the LU. I have seen some opinions that these electric-shifting LUs want to run a particular type of lubricant (something like OMC Hi-Vis), rather than just generic LU lubricant. Don't know too much about that, maybe someone else will.
