rcspencer1
- Joined
- Sep 21, 2001
- 17
I replaced the water pump with no problems, but when I try to put the shaft back in to the head, it engages but as I get to the very end it seems to disengage, so not sure why. I seem to be missing the o-ring (# 32 in the attached diagram), so going to try that. I don't understand why an o-ring would cause it to disengage and the gears seem to be slightly worn but not to the point where I would have to replace it, but just curious if anyone has run into this same problem? A new shaft is about $45 on ebay, so not the end of the world, but we'll see.
Thanks in advance for any advice/counsel you can provide.
Bob S
Bob S
