striperangler9
Thread starter- Joined
- May 6, 2009
- 10
I just purchased a 1971 50hp johnson hydro-static shift. I tore the lower unit down replaced the water pump housing impeller, and metal plate. I also changed the fluid in the lower unit, and replaced the spark plugs. I attempted to start the engine but it will run for about 15 seconds before shutting off. I took out the float needle valve, and cleaned out the carb with carb cleaner. The carbs seem pretty clean. I can keep the motor running by periodically pressing the choke switch. Can anyone give me some insight on this issue please. I'm desperate.
