1971 Johnson 50hp cooling problems
hester5427
I do not appear to have water coming out of exhaust ports. I've recently replaced water pump. Should I be getting water out of exhaust porst continuously? No pee hole on this outboard and I'm not sure if I'm getting water up to the powerhead.
Please help.
Thanks.
tashasdaddy
Re: 1971 Johnson 50hp cooling problems
man, i'm having the same problem with mine, i just pull the tstat, and it looks like crap. will get new tomorrow with sender and gaskets. and let you know what if find. i thinking of dropping the lower an flush the water tube again. i have a infrared therometer, and mine went over 200 with the new impeller.
tashasdaddy
very bottom on the water jacket on the cylinder head, you have to remove the coil, power pack mounting bracket to get to the bolts, on the right hand side. the tstat goes in bottom hole, 2nd up is pressure relief valve.
73rude65
just replaced my water pump and seen my cooling tube was bent..used garden hose to push water up it and saw that midway up pipe there was a small hole, definitly machined, not rusted out..does anybody have that hole on theres? or maybe guy before me put it there??? 73 65hp evinrude...
tomoco
Are you still there?
Mine has a similar hole, just past the bend.
72 65 Johnson.
