1971 Johnson 50hp Hydroelectric Drive
cntryboy
I have a Skeeter Hawk Bass boat with a 1971 Johnson 50hp Hydroelectric Drive on it. Just got this boat . The previous owner had a problem with it shifting. Tore into the Shifter box and rigged a toggle switch up. I need to put it back together with the right parts in it. He still could not get it to work after doing this. Does anyone have a Diagram or pics of how this looks inside so that I can get the right parts in it? But I got the whole boat, motor and trailer for cheap! The motor ran before he had the problem with it shifting!
tashasdaddy
Re: 1971 Johnson 50hp Hydroelectric Drive
good luck, no longer made, you might find a good one on ebay.
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
there are several thread on making shift switches for those motors.
jay_merrill
As TD said, the shift switch is an NLA item. There was another switch that was very similar, but it didn't have the neutral safety feature (white wires, allows enagement of starter) in it.
If you end up finding someone who has an NOS switch for your remote control, expect to pay dearly for it. I have heard of prices of as much as $400. Sometimes you can find a used one, but I wouldn't pay much for it even if it is working, because there is no way to know how long it will remain functional. Another possibility is to find a complete remote control on one of the auction sites, outboard boneyards, etc.
The better bet might be the switch that doesn't have the neutral feature. I have seen these for as little as $60. The trick is to actually find one.
You can replicate the function of the switch by using toggle switches, but you have to be very careful not to "slam" the gearbox, by inadvertantly hitting the switch and changing from forward to reverse or reverse to forward, with power on the motor. Accidentally putting the motor in neutral with a lot of throttle could also cause problems by overspeeding your powerhead.
If you do a post search for "hydro-electric Shift," or some variation of that, you will come up with a number of threads discussing this issue.
