I have a 1971 Johnson 9.5 HP. It has low compression, 75 pounds in each cylinder. I purchased a service manual looking for the specs and it is not in the book. Can anyone tell me what compression the cylinders should have?
I finally got around to trying to set up the carb like Joe suggested. To keep it running I had to really richen it up. Does a carb disassembly, cleaning and rebuild sound like it will cure my problem? I am think that the float is saturated and or the carb gummed up and slow speed orifice clogged.
Thanks, Don
Yep, unless you're sure the carb is spotless, like you yourself have cleaned/rebuilt it lately, with the way gasoline is these days, it's a must.Does a carb disassembly, cleaning and rebuild sound like it will cure my problem?
The engine seems to be running as it should although it was running rough and cutting out at slow speed idle. I adusted the slow speed idle knob on the side of the throttle handle and adjusted the lean/rich until she evened out. Like i said, it seems to be running good but I lost some range on the throttle handle between start, shift and slow positions.
Hey guys - this thread is 1-1/2 years old.
