My top wire isnt providing any spark. I know this is probably a newbie question, but what should I check first. Also, if something will have to be replaced, more than likely what would it be and is it something I could do? I have done everything else on this motor (carb rebuild, fuel pump rebuild, lower unit seals, and manual recoil work.
another question is that if it needs the ignition parts (coil, points, etc...) is it as simple as just taking the old ones off and reinstalling the new ones? Or do I have to adjust them, and also mess with adjusting the timing? This is entering an area I have no experience with. I was hoping it was easy as pulling the old stuff off and putting on the new stuff.
thanks
Matt
thanks
Matt
