Its been many years since I've been on here. Just picked up a new boat and have some questions (gotta start remembering how all this stuff works again. haha)
As far as I know, its been sitting minimum a year. Before I start throwing money into it, I figured I would do a compression test. I've seen some conflicting info on how to do this.
1) pull all the spark plug wires
2)remove plug and crank motor
3) repeat?
Im assuming its important to make sure you have a good charged batter also.
And since its been sitting, should I spray some fogger in first?
Is that all there is to it? I saw stuff about removing all the plugs then testing. I've also seen you need to start it up and run it (not an option at this point)
3) repeat?
