1971 merc 4hp wiring
The-Machinist
I have a 71, 4hp that has no wire running to the negative side of the coil. Where should the wire run from? does anyone have a diagram for this engine?
Thanks for any help, shawn
Laddies
Banned
Re: 1971 merc 4hp wiring
It goes to the points-- If your going into the repair business you need manuals or experince Shawn!
The-Machinist
easy now, who said anything about going into the repair buisness? This is my first single cyl merc, and I have never worked on one before. It was given to me by my uncle, and I just wanted to make it run again. I have several 2 cyl mercs and i am familar with the wiring on those, so I figured I could figure it out. With no switchbox, im lost. It has a green wire and a yellow wire coming from under the flywheel, thats all the wires on it. they are both cut about 1" long. Im not trying to **** anyone off, I was just hoping for some advice before the manual comes in.
Thanks, Shawn
The-Machinist
So, does anyone know if the yellow wire goes stright to the negative side of the coil, or was there supposed to be any thing hooked between them? I have tried to jump it to the negative side of the coil, with no results. Is there something I'm missing?
Thanks for any advice, Shawn
