Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
Have had this motor going on 4 seasons now and have struggled with this issue since I got it. I've managed to "get by" with it by goosing the throttle as it goes into gear but I can not confidently shift gears while docking etc., without it stalling at the worst times. I'm not prepared to put this boat back into the water until I've fixed this problem.
I have gone thru the link and sync procedures countless times with no success. I'm pretty sure I understand the procedure and I've followed it step by step, over and over again. Motor starts with a touch of the key and will idle reasonably well in neutral at about 800rpm. As soon as it goes into gear it stalls. Compression has been measured at between 130-135 across all cyls. Carbs were torn down, thoroughly cleaned and rebuilt last season. Motor runs very well once it gets past the stalling. Good holeshot and runs at WOT for extended periods of time without issue.
Here is where I'm at. Please, if you can offer any advice or direction I would be ever grateful.
1) TDC verified against timing sticker with dial indicator.
2) With #1 cyl at TDC, flywheel aligned with timing decal,
the distributor pulley seems to be off alignment CW 1/2 tooth.
Ideally the flywheel, sticker and distrib timing marks should be aligned
3) If I align the timing marks on the distrib pulley with the flywheel
the flywheel timing mark aligns at 5 BTDC on the timing decal.
4) Primary carb pickup is set at 6* BTDC, by sticker.
5) Max advance timing set at 21* BTDC, by sticker.
6) Secondary carb pickup is set to engage at max advance.
7) Carb idle screws initially set 1 1/2 turns out from seated. Have adjusted in AND out 1/4 turn at a time with same stalling results.
8) With the motor running at 800rpm in neutral, timing is between 0 and 2* BTDC.
9) Put the motor into gear (FWD or REV) and it stalls everytime.
10) Touch the key and it starts right back up.
Help please.
Ideally the flywheel, sticker and distrib timing marks should be aligned 3) If I align the timing marks on the distrib pulley with the flywheel
Help please.
