fullthrottle
Thread starter- Joined
- Sep 12, 2008
- 20
Hi there, i have a 1971 mercury 650 4cyl wich is only getting 1900 rpms on the lake, now it seems like it kicks in fine but tops out at 1900rpms and 12mph. It runs great, no hesitation, sputtering or anything. I replaced the plugs, didn't help, did compression test all were spot on, spark is good, checked all the fuel lines and the fuel filter, all seem fine. I tore everything apart thinking maybe the carbs were just gummed up, they looked great, cleaned them anyway, put everything back together and fired it up, ran the same, in the driveway if i try to rev it up in neutral it sounds like it's trying to hold itself back from revving up. also when i look at the plugs from running it on the lake, and at the house they were oily, not a mixing issue because i thought that right away and filled a new tank and ran it, same thing happened. Also looked at the diaphram in the fuel pump and the check valves, looked allright. anybody with any info on this would be greatly appreciated, thank you
