1972 1150, cylinders 3 & 4 not firing
bunker108
Been chasing ghosts all season after no problems last year. It started bogging down fully loaded so I pulled the three carbs for a good cleaning and some new gaskets. The carbs looked good but the middle carb now leaks when I prime the bulb. Could a high float level cause those cylinders not to fire? Can an adjustment be made to the middle carb?
I have compression and spark on those cylinders.
How do I verify that spark is hot enough on those holes?
The engine starts easily and idles nice. When I pull the wires on 3 and 4 it doesn't affect the idle.
Please don't tell me I will need to pull the carbs back off...
Thanks for any help!
bunker108
Re: 1972 1150, cylinders 3 & 4 not firing
I don't see any signs of water intrusion on those cylinders or any others. The plugs dont look bad either. All evidence is leading me to that middle carb.
Chris1956
Honorary Supreme Mariner
I agree, the middle carb should not leak. Replace the float and inlet needle and seat. These parts do not last forever. The #3 and #4 spark plugs are dirty right? Not steamed cleaned? Check the plug wires for arcing to ground.
bunker108
Ok it looks to me that 3 and 4 are steam cleaned...6 is a little cleaner than the others too...
What do you all think? One is on the left, 6 on the right
Chris1956
Steam cleaning means water intrusion. On cylinders 3 and 4, it means a leak or hold in the exhaust baffle or inner exhaust cover leak or hole.
Chris1956
if plugs #5 and 6 are steam cleaned, water could be getting past lower crank seal. If plug 5 is dirty, it could be leaks from both areas.
bunker108
yeah it looks like this one will need to come apart. In the meantime I am on the hunt for a substitute engine. Have a cabin rented near a lake for 4th of July!
