1972 ?? 1150 merc 6cyl power of tower ser. no. 3370711
MACH1SCJ
The brown wire is currectly hooked upto the stator junction block. The wiring diag shows it should goto the switch box. What do you guys say?
Barnacle_Bill
Re: 1972 ?? 1150 merc 6cyl power of tower - brown tach wire stator block or switch bo
It should be connected to one of the yellow wires coming from the stator. The connection is made at the rectifier where both yellow wires are teminated.
kazek
that depends what tachometer you are using.for original merc tach from that era use brown wire connected to switch box(it uses dissy signal).for new tach use stator signal(as above tread)
MACH1SCJ
How do I tell if it is an orignal tach from that era?
There was a wire at one time on the switch box but was already removed when I got it.
If supposed to be driven off switchbox, Tach will probably say "Mercury" or "Quicksilver" on it. It will be real old as well(mid seventies or older)...Most likely you have an aftermarket tach that wants to read stator pulses.
kazek
MACH1SCJ
Morning, and hope everyone survived the storm with no damage.
Finally found the SER. NO. 3370711
Can someone explain the vacuum hose on the motor. I am a 20yr ASE tech. So get as technical as you want.
Still have not gotten fuel Lines, been bustin my hump all week at work. Nice to be off!
More tear down today. Here's the progress.
Pics to come.......
MACH1SCJ
Re: 1972 ?? 1150 merc 6cyl power of tower ser. no. 3370711
The crank gear bolts look to be staked. Should I remove these or work the timing belt into place?
Engine side with fuel pumps removal.
MACH1SCJ
upper fuel pump & mounting gasket.
carb removal-- is this how you guys do it, to pull the starter? Had to pull the filter screen housings to access the upper carb nuts on top two carbs.
MACH1SCJ
Tach & speedo, lower unit off, port side as I got the boat, starboard side restoreer & wax with an elect. buffer.
Oh it is hot outside. I've been working 12hr days in it all week. I am so glad we got elec, A/C and internet. the rest of the street has no power. Land lines & fios tv is out too but I dont care about that.
For fuel line I think I will go with one of these:
FC234-05 AQP High Temp Fuel & Oil Fire Resistant USCG/MMT NMMA/BIA FC234-5
http://aeroquip.cc/fc234-05aqphightempfuelandoilfireresistantuscgmmtnmmabiafc234-5.aspx
or this
FC234-06 AQP High Temp Fuel & Oil Fire Resistant USCG/MMT NMMA/BIA FC234-6
http://aeroquip.cc/fc234-06aqphightempfuelandoilfireresistantuscgmmtnmmabiafc234-6.aspx
Maby a little nap now.....?
wired247
Just work the belt on in place. lowering the flywheel as you go. No need to remove the pulley from the flywheel.
MACH1SCJ
Think I need a new impeller?
MACH1SCJ
The impeller has no visible wear but will be replaced with a complete housing kit. The drive shaft had grease all up & down it. Is that something I should do is put a coating of vaseline/grease on the driveshaft?
Can I change out the prop seal without taking the lower unit apart? (will it come out the front)? Do I need a sleeve to install the new seal so the prop splines dont cut it?
