jonnymarquis
- Joined
- Feb 25, 2010
- 151
ok i once posted about the idle issue, it would crank but in order to keep it running i had to choke about every 5 seconds. now i can get it to stay running once it warms up but i can not let it idle down at or bellow the start position or it dies now i have replaced the primer bulb checked the gas lines for leaks and pulled the carbs soaked them and cleaned them to a shine. the problem still exist. will not idle low, i also did a compression test each cylinder stayed around 60 psi give or take a psi after 2 seconds each. what else might i check? it does not have a tach so i can not tell you how fast its running when it stalls, but its not that slow, and it just slows it self down and dies, ty for the help
