Watermann
- Joined
- Jan 12, 2013
- 13,845
My opinion is with everything fused I don't see the need for a battery shut off switch unless you have issues with power drain and the battery going dead. You don't turn off the power at the battery for your car or house every time you leave it because everything's fused so if there's an issue like a direct short then it blows the fuse.
My main run from the battery is 20a rated 12 ga primary wire with an inline 20a fuse at the battery. Then you need the same gauge primary for the negative minus the fuse of course. I don't see the need for 6 or 8 ga primary wire and have never seen any factory boat wiring with that size either or your house for that matter which has 20a wiring through it to all the outlets and lights. My trolling motor is the exception to that since it's a 60a rated circuit and relay. All of my accessories are wired with 16 ga except for the LED wiring, I have double strand 18ga for it. Nav and gauge lights are one circuit and interior lighting needs to be separate.
So did you get the rub rail insert in alright?
