- Joined
- Oct 25, 2011
- 25,254
Anyone ever try that USC All Metal body filler?
I have some of their aluminum AL metal filler, but haven't used any yet. I plan to, probably on the grinding damage on the bow of my Duracraft.
There probably isn't any filler on the interior side of those ground off rivets, so my suggestion to use a washer or plate was for on the outside of the hull to make sure you didn't chip any of the existing well stuck filler off. Since I don't know how bad (probably fairly minor if it doesn't show much on the inside) and really how thick it is, I figured a small plate would spread the load over a larger area then the 'pop' rivet head of a closed end blind rivet and prevent it from chipping long term.
If in the process of drawing the rivet tight the filler pops/chips at the thru hole, if bad enough, it might compromise the sealing of the thru hole and cause the rivet to draw down below the face of the filler. That'd be less then ideal too........
