Re: 1972 19' AeroCraft Help Formulating A Resto Plan
Transom remake took place today. Hopefully this one will come out better.
This time went through the trouble of making a template to try and get a better fit across the bottom. The first one was a decent fit but didn't account for the angle between the trans and the floor, so there was a large gap.
Is there a pattern making 101 thread? If not I think I took enough pics while I was at it to do one.
I tried a stacked pattern to account for the angle
but neglected to take into account the extra thickness of the pattern material which changed the amount of angle. So I just used a bevel gage to set my jigsaw and cut it that way.
I got a bit better fit but not much
With that done, no real flat place to use to laminate, and inspired by Wood's transom claps I commenced making a jig to make a flat transom.
I took a 10' 4x4 cut it in half, jointed and planed it flat, then used pocket hole screws to screw them to one half of the plywood. I then added an extra hole to the transom clamps in the end and pocket hole screwed them to the 4x4s.
Flip the whole thing over, sealed the plys, and proceeded with the lamination. Once the halves where together I tagged a screw into each corner and clamped it up just enough to give a bit of squeeze out. I also added a few screws down the outside edges just for good measure.
No that's not clamped down. I took the pic when I got done setting it up on my trial run. But you get the gist.
Hopefully in the morning when I get up I'll have a dead flat lamination.
I will have to refit a bit, since somehow when I put the alignment screws in instead of dropping in the holes that where there from previously being screwed together while I fitted it they made new ones about an 1/8" off. So much for all the painstaking work of the first fitting. :facepalm:
