Re: 1972 20 HP Mercury prop question 2 or 3 blade
You may be better off posting this in the Prop forum, or calling your local prop shop.
Generally, the addition of another blade increases the total blade area in contact with the water, requiring a DECREASE in pitch, otherwise the motor may not pull near the same WOT RPM. You want to watch WOT RPM, keep that in the mid to upper side of the recommended range for you motor to prevent excessive engine loading.
