1972 40 hp merc....want fire
COACH_J
i have a 40 hp mercury that for what ever reason want or has quit firing on both cylinders, any help would be grateful, what controls the fire or what can i check first......thanks
Laddies
Banned
Re: 1972 40 hp merc....want fire
Here's the test from CDI
COACH_J
ok thanks i will run to town and pick up a ohm meter
COACH_J
ok what i found, was everything was up to specs, what i did was unhook the kill switch, the dealer had installed a cpl weeks ago, took their word it was test run.....no kill switch, motor cranks right up, but want cut off, could this be in the switch, now im not trusting the dealer who worked on it, to carry it back, is it away i can trouble shoot the switch?
Laddies
Banned
Use the ohm meter to track the problem down, hook 1 wire to ground and just work backwards till you find the problem
