Mike Giglio
- Joined
- Jul 25, 2005
- 33
I recently did a carb rebuild for loss of power problem and much thanks to all of those who helped. I was viewing some problems another member with an old 50 hp motor wrote in about and one of the suggestions made was to check the stator for leaking matter on the block. Well the stator is or had leaked on the throttle side and the above the carbs in the front of the motor and my motor does exactly what the other member was complaining about. It runs real well and then is hard starting and won't take any load. I have a stator that doesn't appear to have leaked on a parts motor. Should I replace the timer base and stator from the parts motor or just the stator? The parts motor is a 72 evinrude triumph. A new stator is 193.oo and timer base was around 350.oo. I'm not sure how reliable old electrical parts would be but I quess since I have the parts motor its worth maybe getting stuck again lol. Does that syruppy good goop on my block indicvate the stator must be replaced. Thanks all <br />Mike.
