1972-73 chrysler 130
pistolp
put my boat out in the water the last couple days and she cuts off in idle and sputters when i take off is this attirbuted to the fuel pump and filler bulb i think she just isnt getting the constant flow of fuel but im not sure can anyone help me out
jerryjerry05
Re: 1972-73 chrysler 130
Check for water in the fuel.Have a tach? The rpm might be set too low. The squeezie might be defective.Get a good quality Merc or OMC brand.Jerry
srf9000t
have a 130 hp chrysler ran last year havent started this year with 1971 chrysler couier bowrider and trailer for 1200.00
Frank Acampora
Do yourself a favor before you go crazy:
Just on general principals, replace the fuel pump diaphragm and gasket. If you have the glass bowl fuel pump, the diaphragm is the same as all Chrysler/Force except the bolt holes are 3/16 instaed of 1/4. If you are dead set on buying the correct one, however, go over to The Chrysler Crew. Franz will sell you one but he will be expensive, If you have the fuel pump mounted on the bypass cover with the black plastic inlet and screen, then the diaphragm and gasket are the same for all engines up to at least 1990--so get one at the local Merc dealer.
Change the sparkplugs. These engines are notorious for fouling plugs and then, while they may start, idle is very poor and they may not accelerate from idle without stalling. Also, if the engine sounds like it is dying lean, check carbs to see that they are not clogged and check low speed needles to see that they are not too far in--usually about 1 turn out from lightly seated is reasonable.
Check to be certain that the idle speed is 700-750 RPM IN FORWARD GEAR, IN THE WATER.
Now, if this does not help the problem, then start checking the fuel system, the distributor cap for carbon tracking, and the ignition system.
Frank Acampora
I forgot to mention in the last reply: That engine should have electronic ignition signaled by points inside the distributor. If it indeed does have points, even though they are only for signal, they still must be clean and must be set to .010 open on the high point of a lobe.
