1972 85 hp electric shift. Need Repair manual
hawk_surfs
hey if anyone has a manual can u make me a copy or tell me where to get a free one. solenoids went bad, i think, and i cant find out where the wires are to be reconnected. or can a 1973 manual shift be mounted up. help please
jay_merrill
Re: 1972 85 hp electric shift. Need Repair manual
C'mon now, if you can afford to fiddle with an outboard motor, you can afford to buy your own manual. Try EBay - you can probably pick one up for a bout 10 bucks.
tashasdaddy
nothing mounts up to it other than another hydro-elelctric shift. outboardbooks.com.
if solenoids are shot, good luck finding replacements.
this is not in the manual.
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
