wrench 3
- Joined
- Aug 12, 2012
- 2,108
Replacing the rectifier won't restore your spark but a bad rectifier will take away your spark by destroying the power pack. However, hooking the battery up backwards would take out both the rectifier and the power pack. But would most likely not harm the stater.
The stater can be checked with an ohm meter as a preliminary check but you need to take voltage readings with it running to say for sure that it's OK. I don't have access to the specks and procedures at present but they should be in you repair manual under ignition troubleshooting.
