Leatherdog
Thread starter- Joined
- Jul 22, 2010
- 13
I have a 1972 Chrysler 105 with Magnapower ignition. I have cleaned all connections and performed the following test procedures and still cannot figure out why I still have no spark.
1. I have power to the starter and it cranks the engine.
2. Checked with inline spark checker on all plugs. No spark.
3. Used a 4 cylinder spark board. No spark jumping gap.
4. Checked voltage at blue wire which was 12.3v and cranking 21.1v.
5. Connected voltmeter to white/black wire while it was connected to the distributor and rotated engine by hand which went from 12.3v to 0.2v
6. Disconnected white/black wire from distributor and scratched it against ground and produced sparks but no sparks touching it to distributor housing?
7.connected DVA to voltmeter and checked gray wire going to CDI box and got 132.1v
8. Checked both sides of the breaker by terminal hub and had 12v on both sides.
9. Removed belt driven distributor. Used a points file to clean points and then did an ohms test while slowly rotating distributor (removed) have resistance when points close. Set gap to .10 and then reinstalled distributor lined up TDC and the curved line on top of distributor to the flywheel.
CDI makes high pitch noise with key on.
At a loss now as to why I have no spark. Any help would be appreciated.
