1972 evinrude 9.5 outboard
poger1973
Any help would be greatly appreciated. Having problems with outboard idling will idle just fine with cover off, replace cover runs for maybe 15-20 seconds and dies, take off cover restart it idles fine I am stumped. I dont want to start messing with things i have no business messing with because it was running fine. By the way cleaned out screen on fuel pump still doing same thing.
floatingwoody2006
Re: 1972 evinrude 9.5 outboard
sounds like the exhaust gasket is bad. They are a bear to replace if you can find the part. Some people have drilled small holes in the cover to help. I have not tried. Good luck. Is this in the water, or a barrel?
