1972 Glastron v173 restore
infrared
Hello everyone. I wanted to document and share my restoration project. This is my first restore so I'm sure I will make mistakes but also learn a lot.
I bought it last season (2017) knowing the condition (everything rotted) and that a restore was inevitable.
Here's a picture of it right after I bought it
yr9pyA_ZhyKEDB4CvbCLktodExuGPSnKDRpXZx2seHew9tqvdN_A5MHoElp44kioZ-NRKowRxa3BG17ZKMj-=w1483-h815-rw
Gah! I have more updates and pictures to share but I'm trying to figure out this post editor.
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
infrared
Here's the interior
iDpHitxIAYVRWp-Eg8rMVxMPpkL5lJRgYb2pEB7E3SlrE9Y-gE81dfcAL7fpSE5PT04yiG9aFFRsd-UrwGzG=w1483-h815-rw
Launching
x0VkSe5MPi7EO8vGoZ_S5kNhltp1x-3CHoUoilZw6c7lGiYocsVMCSmBxG3XzH8DtT-PHw3jbhYXyKqNVKlr=w1483-h815-rw
She rips
qPspenrmgewj4hcHYDpmh5vtFxh4isB2Uol3B-TBLYjzR1wP3w-mibHH_umjrI4kmgb5S3cfUPhZ76DCmPTN=w1483-h815-rw
Fun's over... time to get to work
mHPQU99W8Y59dbEobxrYq0PYByvOBrTamdAHoBXRQc3jRUu-qyCtoVLITZcqwm0H2iihvh1EfOG64Psryqlk=w1483-h815-rw
Son helping building a frame to take the cap off
Lrpcya0nkZ6fKTVCsY_4ro2HF-dv4L44Iyg-4ELnv3zekxqP6hLPfuc4LWhx_On-v5tibteUp9woCKySWqts=w1483-h815-rw
Cap's off (by the way this is all wife-approved)
quujEpIs3YW46qXmym0Ow8s_F5M0h_8VxttbUNTUi3mudlc7yI56iZTgGrp2h0IWw6R-KyrVmHhoY1RwTiEB=w1483-h815-rw
infrared
Here I already removed the rotten transom (wish I took some pictures of it), and cut some of the floor out.
CGvXieoCvKOEOAEZypjdtdqHTzqzixpCW8kemBKN0loIYK-KvN_O-n8MMV3VK7ZdZA4HQ0Yvijoc-WekZiyw=w1483-h815-rw
Removed flotation boxes
VU9iz9Zue1vl5LEifpGFEXq2puhR4MkPg1qWezT62QQoEwopDgvu7WePBUZRgywEXtsjGdDwFxjyM4okxiz4=w1483-h815-rw
ZAvFgiiG7xWXpHnV2EL5rxHmSX8_w9ngnakd2fA5cbdm5m97tW5Rrh3PIz52JHg2COkomujnILU_B-7CrJ8y=w1483-h815-rw
infrared
For the transom, I will be using Coosaboard. Here I am making at template.
Wn3X0TdVGqxL-AQTsIrRd_rM43tArSwTUdNhpdMpFAyMmGNe5EZLQDlc4JmXmXYF9iNrGeEKAU2ARty-PHnn=w1483-h920-rw
Template #2
g8NFfv3GAQANCbKajTVjaZsoMtuw6JXN3zisdxWN68GL6LBDs58vawRnAEF5ZBPHYTK7iENqlujvvAqcoLiT=w1483-h920-rw
And here's the new transom ready for epoxy
49hcus4_ekiPRAwKsSVxf-2xhF1zRmnDKANgNrxfZLWlu2FTIAABE_tL9Ft-_N72athtTywUzUV15rZe-72N=w1483-h920-rw
Panoguy
Hi there, infrared: I grew-up really liking the look of those Glastron boats, I look forward to watching your progress. It seems that you're having difficulties with posting pictures however... I wanna see!!!! Good luck with your build!
infrared
Hmm. I tried to link them from my Google drive... they showed for a little while, but not anymore. I'll try amazon
infrared
Ok here we go again. Copy/pasting with different links to the images:
Here's the interior
Launching
She rips
infrared
Copy/pasting again with updated image links (hopefully they stick this time) :facepalm:
Here I already removed the rotted transom (wish I took some pictures of it), and cut some of the floor out.
Template #2
Panoguy
Wow - in for a dollar!
I looked-into Coosa for my work, but balked at the price. That transom will NEVER need to be replaced again! Are you going to make Coosa stringers also. Great pics, I NEW that this was going to be a fun thread to watch!
infrared
Yes. I plan on using coosa for the stringers. The transom piece was $247 with shipping, but I have enough left over to make another transom for a future project boat just like this (I'm a sucker for old Glastrons).
infrared
Update:
It's COLD! :mad: Spring is nowhere to be found.
Here's my overall plan for the transom/floor/stringers:
  1. Epoxy the Coosa to the transom, but no tabbing
  2. Put the cap back on the boat. The stern is very flimsy, and I can wobble it back and forth a few inches. I do not want to tab the stringers to the transom without knowing the stern is in it's correct (wobble) position.
  3. Remove/Replace the stringers one by one to maintain hull integrity
  4. Install the floor from the stern to about midsection.
  5. Remove the cap again. I'm hoping that with half the floor installed the hull will keep it's correct width
  6. Install the remaining floor up to the bow (can't install it with the cap on)
  7. Install cap.
I also plan on using nida-core for the floor. I'm going to order a small sample, glass it, and then determined if that's the route I want to go.
infrared
We had one nice day this past weekend. Didn't have enough warm hours left in the day to do any epoxy though :(
I cut a piece of plywood to sandwich the coosa while the epoxy dries, and also drilled holes
When I do epoxy, I plan on covering the plywood and bolts used to hold the sandwich together with mold release.
Just waiting on more warm weather now!
hvymtl939
Amazing work! Old Glastrons are my favorite hulls. I'll be tagging along for this one.
infrared
Finally got the transom installed.
Hopefully the mold release works well and I can remove the bolts and plywood! :eek:
Also, when I bolted it together a lot more epoxy got squeezed out of the bottom than I had planned. So now there's no flex in the stern, and I'm concerned that the cap won't line up. I have a plan B if that ends up happening, but I really don't want to do plan B :cold:
hvymtl939
That looks super stout! Going to be putting that 88 back on for power, or going bigger this time around? I bet a big 4 cylinder OMC motor would scream on that thing.
infrared
We'll be using the 88 again. It's plenty powerful and runs very well.
Plus using coosa board vs plywood will lighten up the boat.
infrared
Well I'm trying to get the cap back on to help hold the shape of the boat while I install stringers and tab the transom... and it's a pain! Does anyone have any tips on how to do this? I can get a small section seated and it pops up somewhere else.. it's like a game of Whack-A-Mole.
I can get the bow and stern seated.. but the sides are the most difficult. As soon as I start pushing a side in the stern or bow pops out.
Maybe I can put in temporary screws as I go along :cold:
89 resorter
Never had to pop the cap of mine but I'm thinking you may be able to wrap a couple of ratchet straps around the hull and connect them towards the center of the boat. This way you could tighten them and pull and hold the sides while you work the cap on from the ends. You would like have to sacrifice the straps since you would have to cut the hooks off since they would not pull through after it is on. Good luck on however you make it happen and looking forward to seeing it back together.
