- Joined
- Jul 23, 2011
- 52,769
Make sure to inspect the splines in the 3-piece vertical drive shaft
^^^^ Kenny got it.Just change the oil in the lower, you can use automatic transmission fluid as a substitute.
Hi Scott. I’m unsure whinch splines you’re referring too. I’m not taking anything apart just replacing fluids for now. I checked the ball gears and they look good. Just worn paint.Make sure to inspect the splines in the 3-piece vertical drive shaft
When you pull the drive apart to replace the raw water pump that has been neglected. Check the splinesHi Scott. I’m unsure whinch splines you’re referring too. I’m not taking anything apart just replacing fluids for now. I checked the ball gears and they look good. Just worn paint.
If it’s not broke, fix it till it is.When you pull the drive apart to replace the raw water pump that has been neglected. Check the splines
