jrttoday
Thread starter- Joined
- Feb 8, 2010
- 1,081
I've had a couple or three mechanics look it over with NO success; if at first you don't succeed.... keep on suckin til ya do succeed!! I have a fair amount of mechanical experience, just not with outboards. It's hard to find anyone having experience with these dinosaurs, so I'm asking here.
Over the past two years, this is what has been done ---- new power pack/coil and rectifier, used stator (checks OK), impeller, carbs rebuilt and fuel lines changed out, new fuel pump, and believe it or not - a brand new still in the box distributor cap! I have a new 1,000 amp battery, good compression (low hours), freshwater only until I bought it five years ago - brackish/fresh now.
THE PROBLEM!!! In the water, after idling out from the ramp, it begins to cut out (depending on how warm the water is/warmer = sooner) and cuts off. It will restart immediately, but after a few times, 1,800rpm is max. At home w/muffs, it knocks off after the engine warms. It's probably simple, just haven't found the answer.
There is/are heat (a) sensor(s) in the head - I only see one lol, Is that the problem? How do you test it? etc etc any help! THANKS!!!
you can teach an old dog new tricks, ya just can't teach a new dog old tricks!! at least it seems that way...... hahahhaaaa
