starkizzle
Thread starter- Joined
- Jul 21, 2016
- 52
Hey everyone, I had this boat up and running last season thanks to a lot of help from members here so I am hoping for alil luck this year. I have a 1972 Johnson 125 electric shift that wont start. I replaced the starter and solenoid thinking that was the problem. still nothing.
So, I HAVE POWER to the top post of the solenoid, and power at the two smaller side posts when you turn the key, but no power coming from the bottom post to starter. I checked the neutral safety switch and its functioning according to my multimeter (Reads 12V when depressed, no power when in gear).
The strange part is that while testing the leads on the solenoid and turning the key, it did crank once. So I hooked up the water and tried cranking it. It did crank for 30-45 seconds and then just died again.
This "phantom" start was strange because after I replaced the starter and solenoid nothing was fixed. I went back out today to look at the neutral safety and check some wires, but I had been turning the key off and on several times leading up to it actually cranking. Then It stopped just as sudden as it started.
Any advice would be greatly appreciated.
