1972 Johnson 20 HP Hard to Pull
amvaneyk
It almost seems like there is too much compression. When I pull the plugs out of course is easily pulled. But when the plugs are in even the electric start has a hard time turning it over. Any suggestions??
mables
Re: 1972 Johnson 20 HP Hard to Pull
Most higher HP motors have a compression release to make them easier to start, I don't know if you motor has it or not but if it does it may not be working properly. Maybe someone else will let you know for sure wether it does or not.
tashasdaddy
20 hp does not have the compression releif, is it in gear? that makes them harder to pull.
amvaneyk
no its in neutral
kbait
They are a bit hard to pull, just the way they are. Make sure your battery is fully charged, and all connections are solid for the estart to spin correctly..
bktheking
It shouldn't be that hard, now a 40 with no compression relief- that's hard. Pull the flywheel, maybe the coils are rubbing or something came loose.
oldcatamount
Had that happen to me once. come to find out, the ignition points were gapped to close. Might pay to check that.
amvaneyk
I pulled the fly wheel everything looks normal.
The only thing I can think of that has not been mentioned is carbon buildup. If the combustion chambers are full of carbon, they will be artificially small which could cause artificially high compression. It may pay to decarb the engine, or pull the head and examine. Pulling the head will allow you to inspect the entire upper end as well.
kbait
If it pulls over easily w/o plugs in?? Maybe a screwy recoil or e-starter..
