1972 Johnson 20 shifting problem
johnson72
Re: 1972 johnson diagram
Thaks for the diagram. Something is wrong with my gears or linkage from the shifter because when i shift into forward, it stays in neutral. But reverse is fine. Does anyone have any ideas?
johnson72
I have a 1972 johnson 20 hp model 20R72. When i shift into forward, it stays in neutral but reverse works. I was leaving a bay and it popped out oof forward and into neutral, but the shifter was in forward. Can anyone help?
tashasdaddy
Re: 1972 Johnson 20 shifting problem
has the lower unit been off lately? the shift connect bolt has to go thru the indention on the shift rod.
tashasdaddy
double post only serves to confuse you and members. not appreciated on iboats.
johnson72
I dont know why it double posted here. The lower unit hasnt been off lately that i know. i bought it a few months ago but it has worked fine since i bought it until a few days ago.
tashasdaddy
take the 1x3 plate off the side of the motor leg, check the connection, the bolts must go thru the indents in the rods. if that is correct, the handle may have slipped but very doubtful. or the forward gear and clutch dogs are going out in the lower unit, not unusual, for the age of the motor.
johnson72
Reverse still works. I was leaving a bay and it just went into neautral, but there wasn't a clunk or any sound.
johnson72
What do you have to take off to get to the linkage under the carb?
14ftgrumman
Why would you want to get to the linkage under the carb? You have a shift-lower unit problem.
Follow Tashasdaddy's advice.
Remove the plate on the lower unit and make sure that the shift rod is connected properly. I've got 2 of these (1 20HP and 1 25HP) He's right on the clutch dog. I have spare everything for these.
They are very simple to work on, just get a factory manual. I've got a Sealoc, but I will find a factory manual one of these days.
johnson72
So it could be the clutch dog even though there wasn't a sound?
14ftgrumman
Yep. Clutch dog wears on the ears, it doesn't brake-usually
kbait
I had one act weird like that, and the shift fork (that actuates the lateral movement of the clutch dog) was bent and not mated to the dog correctly. I bent it back and it worked fine. Hope it's that easy for ya!
johnson72
Thanks for the advice. I will see if I can fix it this weekend.
johnson72
I fixed it. A pin behind the prop broke in half and got caught on the prop. It runs great now.
johnson72
It happened again! Does anyone know why a shear pin behind the prop would shear even though I didn't hit anything?
Daviet
Are you using a factory shear pin or making your own?
johnson72
I have two questions. Would the clutch dog slipping at plowing ( before you plane) mode break the shear pin? If the clutch dog is worn, would it slip and then work for a few days and slip again?
