ok I always run them in a 55 gallon barrel about half full of water and it will idle decent now about 830 rpms or so, put it in gear and it will rev all the way up without bogging down , and this carb is fine, I found a small spot on timing plate that raises the idle some but its fine,
I may take a small file and rub it off so its concentric , it revs fine under load wot wide open throttle ,
no flusher involved , run in a 55 gallon barrel about half full, thanks
