andrewbabich
Thread starter- Joined
- Aug 31, 2009
- 85
1972 Johnson 50 does not want to start after the winter.
I drained all gas and filled it up with fresh gas. (i did use last weeks 93 octane 32:1 premixed amsoil mix I made last week for my dirtbike that I had at the house, I wonder if too high of octane and too much oil could be my problem)
Has fuel, spark and compression and will crank all day long.
The plugs come out wet after I crank it. (so then I let it air dry for 10 min to an hour and retry, still no luck)
The plugs have spark when I check them.
Each cylinder has 135 compression
I spray the intake with starter fluid, and also try spraying it into each plug hole. I also try starting it without starting fluid. No luck.
It sometimes fires for one explosion the first time I crank it.
The last time it fired for a split second cranking will immediately stop. Like it got a signal that it was starting or something so it kills the starter.
Immediately I can turn the key again and crank it for another 5 seconds or however long I want but it won't catch.
I have the choke start/run lever all the way up to start postion and also try it at 3/4 up. I'm also holding up on the electric choke toggle switch below the key while I crank it.
This motor is always a pain in the butt to start but this year after winterizing its just not co-operating and I have no idea what to do.
I'll try new plugs, but the current ones have spark.
