1972 Johnson 50H/P Factory Prop??
wildcard_55
hello again. One more question if I may. I have a 1972 Johnson 50 h/p pleasure motor. it has at this time a 13-3/4x15 prop on it. is there any way to tell or find out if this is the origonal factory issue prop for this year and model of engine? it is on a 15 ft caravelle tri hull crappie/bass type fishing boat with a rear center console. with the live well in the middle of the boat. Thank you all again in advance.... old sp/4 trying to be a sailor..
countvlad
Re: 1972 Johnson 50H/P Factory Prop??
i think its going to be either realy hard or imposible to answer that question... is there a reason why you need to know if its original or not? do you have problems with the prop/ boat?
steelespike
72 catalog says 13 3/4 X 17 was standard issue though many other sizes could be substituted depending on the application.
wildcard_55
thank you all for your help. I was just trying to figure out if my prop was wrong for my boat and change it or just leave it be..thanks again....
countvlad
its possible it could be the wrong one... if it came with the motor that doesnt mean its the rigt one for the boat....
what are your RPMS at WOT???
