Tonygotskilz
Thread starter- Joined
- Apr 19, 2003
- 38
Ok i have another post going about my shift problem, which i think i've handled, but now i can't get the motor to turn over at all...<br /><br />I checked the battery its got a full charge (with a multimeter) and everything is connected. The toggle switch for the choke works, and you can see the choke move on the engine, but when you turn the key NOTHING happens, the flywheel doesn't spin... nothing...<br /><br />It started just fine last week when i was working on the shift problem but all i touched was the shift wires (its a hydro-electric btw) so what would be causing it not to turn over now? <br /><br />I did get the overheat warning horn last time i tried to start it when it was working (last week) but i figured it was because something grounded out, is there something on the motor that needs resetting after you get the horn? This is really odd to me, never had a problem starting it before...<br /><br />Anyone have any clue whats going on? What should i check for? and where should i check, it looks as if every wire in the engine is connected fine and i check the one fuse i could find in the engine (a really little round fuse)... I'm baffeled?
