billy4hp
Thread starter- Joined
- Jan 31, 2009
- 245
Hello all, great site, what a wealth of knowledge around here... So I am looking to tap into a little bit...
I recently acquired a 1972 Johnson 9 1/2 that I plan on using as a kicker / emergency spare on my also recently acquired 16ft Glasply (Pacific NW boat for those not familiar)... Anyways is this OB a reliable kicker for all day trolling, etc?
It has been kind of a mess, previous owner bought it off Craigslist and that previous owner did some work or had some work done that wasn't up to snuff. Tiller handle was stuck due to the carb linkage being jammed, thermostat housing was leaking, etc.
I got it running on a saw horse w/ hose and the water stream is good, engine runs decent but will "sneeze" every once in awhile, almost seems like a lean condition as it's not just a consistent "bump" like it's a ignition miss.
Really have not run it that long, it's a bit cold up here (40 deg F) and I know some two strokes doen't really enjoy the cold weather so I don't know if that has anything to do with it...
Haven't done a compression test yet but the spark plugs look reasonable for the little bit of time I have run it...
Since I have everything all buttoned up I am going to really give it a run tomorrow up to operating temp and see if it smooths out with a bit of heat in it...
Thanks for any and all advice,
Billy
Billy
