hooter85742
Thread starter- Joined
- May 6, 2011
- 12
Okay I have a 1972 johnson 40hp. I have 2 different lower gear boxes. one is 6 inches longer than the other. The shorter one puts the top of the prop right at the bottom line of the boat. The longer one has it 6 inches below the bottom line of the boat. Oh the boat is a 1972 arrow glass 14 foot 7 inch v bottom hull.
I also have more than one prop I have a 10x10 10 1/2x10 and a 10x12. I have used the 10x10 and it will not get the boat on plane. the 10x12 gets the boat on plane with the lower gear box and a tail andded to the motor. The tilt is at the last hole the last spot away from the boat. But put it to the hole at the closest to the boat and it pushs the front of the boat down into the water at full throtlle. That should give an Idea about what I have now. Speed wise its not fast.
