JohnnyReckless
Thread starter- Joined
- Jun 23, 2018
- 6
Q1: Would the carb rag smother test indicate a clogged jet when air intake is blocked on a triple?
Q2: I did notice that his skeg was bent to one side about 1-1/2, could that cause prop-wash?
Q3: Would a worn shift dog coupler in lower unit maybe slipping?
I'm working on my dads 72 Johnson outboard triple after he hit a log in the water. In general everything "works" hydro electric Fwd/Rev/Neutral etc.Boat will "troll" all day long, just no high speed plane out, seems boggy and slightly more rough/shakey then I remember.
What I've done: I replaced with exact same OMC solid prop and output shaft seems true. Trim is in normal mid-position. Engine starts and idles fine. Warm up lever opens butterflies about 1/8", WOT all the way open, so seem ok. Choke is not on and lever works. Needles adjusted to 1-1/2 turns out. Used SeaFoam spray and soaked carbs, SeaFoam engine treatment in tank. Fresh non-ethanol fuel mixed 40:1. All 3 plugs have nice spark, changed plugs anyways.
I believe that the fuel tank on these Johnson's have to be vented or will die out when cruising so vent cap screw is open after initial bulb prime and engine start. In his driveway with water muff if I choke either the top or middle carbs with a rag the engine will eventually die out but not on the bottom one. When i block the bottom carb. there is no difference in idle, it's like that cylinder isn't doing any work. I have a compression tester but didn't bring it, guess that's the next step maybe.
